Ga door naar hoofdinhoud
Acer Chromebook R11 C738T-C44Z Battery Replacement
Wat je nodig hebt
  1. Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: stap 1, afbeelding 1 van 3 Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: stap 1, afbeelding 2 van 3 Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Battery Replacement, Battery: stap 2, afbeelding 1 van 2 Acer Chromebook R11 C738T-C44Z Battery Replacement, Battery: stap 2, afbeelding 2 van 2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Battery Replacement: stap 4, afbeelding 1 van 1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
Conclusie
To reassemble your device, follow step one and two in reverse order.
Christopher Trinidad
316 Reputatie
2 handleidingen geschreven
Gateway, Team 1-4, Saknee Fall 2021 Lid van Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 530
