Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
The back cover of the R11 is held into place using 11 screws.
To remove, use a screwdriver appropriate for a JIS 1 screw.
Battery is located in the bottom half of the computer.
Unscrew the two screws holding the battery in place. There is one on each side of the battery.
Slide out the ribbon that is connecting the battery to the motherboard.
There are 7 wires leading to it, and each is a different color of the rainbow.
Disconnect the keyboard ribbon located at bottom center of motherboard.
9 andere personen hebben deze handleiding voltooid.
Één opmerking
Hi. Incidentally while you have it apart check for heating of the chip that controls the USB3 port: this is known to be a weak point. As with many low end laptops they can’t run external devices like hard drives properly so may report incorrectly that they need formatting. Fix is to use external power device.
