Wat je nodig hebt
Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
Use the plastic pry tool to unlatch the two tabs on either side of the black ribbon.
Gently slide the black ribbon out from its socket and under the white ribbon.
Één andere persoon heeft deze handleiding voltooid.
