Ga door naar hoofdinhoud
Acer Chromebook CB5-571-C5XU Speaker Replacement
Wat je nodig hebt
  1. Acer Chromebook CB5-571-C5XU Speaker Replacement, Bottom Case: stap 1, afbeelding 1 van 2 Acer Chromebook CB5-571-C5XU Speaker Replacement, Bottom Case: stap 1, afbeelding 2 van 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Speaker Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook CB5-571-C5XU Speaker Replacement: stap 2, afbeelding 2 van 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Speaker Replacement, Battery: stap 3, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Speaker Replacement: stap 4, afbeelding 1 van 1
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Speaker Replacement: stap 5, afbeelding 1 van 1
    • Gently lift the battery out and remove it from the laptop casing.
  6. Acer Chromebook CB5-571-C5XU Speaker Replacement, Speakers: stap 6, afbeelding 1 van 2 Acer Chromebook CB5-571-C5XU Speaker Replacement, Speakers: stap 6, afbeelding 2 van 2
    • Use the plastic pry tool to unlatch the two tabs on either side of the black ribbon.
    • Gently slide the black ribbon out from its socket and under the white ribbon.
  7. Acer Chromebook CB5-571-C5XU Speaker Replacement: stap 7, afbeelding 1 van 1
    • Carefully remove the smaller black ribbon from the motherboard using the opening tool.
    • Be careful when prying the connector loose, its small size can make it difficult to grasp a corner of the connector.
  8. Acer Chromebook CB5-571-C5XU Speaker Replacement: stap 8, afbeelding 1 van 1
    • Weave the black wire connecting the two speakers out of the small metal hooks.
    • It might be helpful to take a picture of how the wire is wrapped around the hooks, as this layout is important when the wire is put back.
  9. Acer Chromebook CB5-571-C5XU Speaker Replacement: stap 9, afbeelding 1 van 1
    • Simply lift upwards on both speakers, and they will remove from their position.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
️Gaetan Charles
119 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 Lid van UMass Dartmouth, Team S6-G1, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G1
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 182
