Ga door naar hoofdinhoud
Acer Chromebook CB5-571-C5XU Fan Replacement
Wat je nodig hebt
  1. Acer Chromebook CB5-571-C5XU Fan Replacement, Bottom Case: stap 1, afbeelding 1 van 2 Acer Chromebook CB5-571-C5XU Fan Replacement, Bottom Case: stap 1, afbeelding 2 van 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Fan Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook CB5-571-C5XU Fan Replacement: stap 2, afbeelding 2 van 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Fan Replacement, Fan: stap 3, afbeelding 1 van 2 Acer Chromebook CB5-571-C5XU Fan Replacement, Fan: stap 3, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, unscrew the screw to the right of the fan.
    • Remember to have a small container to place the screw in, so it does not get lost.
  4. Acer Chromebook CB5-571-C5XU Fan Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook CB5-571-C5XU Fan Replacement: stap 4, afbeelding 2 van 2
    • Using the Phillips #0 screwdriver, unscrew the four screws connecting the heatsink to the motherboard.
    • Remember to have a safe place to place the screws, so none of them get lost.
  5. Acer Chromebook CB5-571-C5XU Fan Replacement: stap 5, afbeelding 1 van 3 Acer Chromebook CB5-571-C5XU Fan Replacement: stap 5, afbeelding 2 van 3 Acer Chromebook CB5-571-C5XU Fan Replacement: stap 5, afbeelding 3 van 3
    • Carefully unhook the black and white wires from the circumference of the fan.
    • It might help to use the pointed end of the spudger tool to unhook the wires.
    • Do not tug too hard on the wires, as they can easily disconnect and snap off from the motherboard.
  6. Acer Chromebook CB5-571-C5XU Fan Replacement: stap 6, afbeelding 1 van 2 Acer Chromebook CB5-571-C5XU Fan Replacement: stap 6, afbeelding 2 van 2
    • Using the spudger tool, carefully remove the wires connecting the fan to the motherboard.
  7. Acer Chromebook CB5-571-C5XU Fan Replacement: stap 7, afbeelding 1 van 2 Acer Chromebook CB5-571-C5XU Fan Replacement: stap 7, afbeelding 2 van 2
    • Using the flat side of the spudger, firmly pry the fan off of the components, as well as the heatsink from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Erin Moffatt
282 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 Lid van UMass Dartmouth, Team S6-G1, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G1
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 298
