Ga door naar hoofdinhoud
Acer Chromebook CB5-571-C5XU Battery Replacement
Wat je nodig hebt
  1. Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: stap 1, afbeelding 1 van 2 Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: stap 1, afbeelding 2 van 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Battery Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook CB5-571-C5XU Battery Replacement: stap 2, afbeelding 2 van 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Battery Replacement: stap 4, afbeelding 1 van 1
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Battery Replacement: stap 5, afbeelding 1 van 1
    • Gently lift the battery out and remove it from the laptop casing.
Conclusie
To reassemble your device, follow these guidelines in reverse order.
3 andere personen hebben deze handleiding voltooid.
Kenneth Bowers
1.381 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 Lid van UMass Dartmouth, Team S1-G1, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G1
4 Leden
19 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 807
