Ga door naar hoofdinhoud
Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board Replacement
Wat je nodig hebt
  1. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: stap 1, afbeelding 1 van 2 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: stap 1, afbeelding 2 van 2
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: stap 2, afbeelding 1 van 1
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: stap 3, afbeelding 1 van 3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: stap 3, afbeelding 2 van 3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: stap 3, afbeelding 3 van 3
    • Identify the port that is connected to the speaker.
    • Using tweezers, separate the cable from the port.
  4. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: stap 4, afbeelding 2 van 2
    • Find and remove the blue tape from the circuit board.
  5. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: stap 5, afbeelding 1 van 3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: stap 5, afbeelding 2 van 3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: stap 5, afbeelding 3 van 3
    • Remove the black tape from the port.
  6. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: stap 6, afbeelding 1 van 3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: stap 6, afbeelding 2 van 3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: stap 6, afbeelding 3 van 3
    • Identify the two Phillips screws.
    • Remove the two screws holding down the board with a J1 Phillips screwdriver.
    • Gently lift the board from the Chromebook.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cole O'Neal
148 Reputatie
1 Handleiding geschreven
2 opmerkingen
Any ideas about where to purchase this part? I am almost certain that it is the problem with my sound. Also, I can get to it no problem, but I am struggling finding a replacement part.
littlemas2 - Antwoord
I have looked on numerous pages on google, both with the part number and with the Chromebook model number and have yet to be able to find a supplier.
littlemas2 -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 13
Altijd: 666
