Ga door naar hoofdinhoud
Acer Chromebook CB5-312T-K 8Z9 Battery Replacement
Wat je nodig hebt
  1. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: stap 1, afbeelding 1 van 2 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: stap 1, afbeelding 2 van 2
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: stap 2, afbeelding 1 van 1
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: stap 3, afbeelding 1 van 3 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: stap 3, afbeelding 2 van 3 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: stap 3, afbeelding 3 van 3
    • look for the battery in the bottom half of the computer
    • Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
  4. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: stap 4, afbeelding 1 van 3 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: stap 4, afbeelding 2 van 3 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: stap 4, afbeelding 3 van 3
    • Begin by unscrewing the two Phillips head screws that hold down the battery using a J1 sized screwdriver.
    • Finally remove the battery from the laptop.
Conclusie
Alonso
224 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 23
Altijd: 1,474
