Ga door naar hoofdinhoud
Acer Chromebook CB3-131-C3KD Track pad Replacement
Wat je nodig hebt
  1. Acer Chromebook CB3-131-C3KD Track pad Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Track pad Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure you turn off the laptop before starting.
    • Unscrew and remove the (11) eleven 4mm J0 head screws on the underside of the laptop using the JIS #0 screwdriver.
  2. Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 2, afbeelding 1 van 3 Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 2, afbeelding 2 van 3 Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 2, afbeelding 3 van 3
    • Use the plastic opening tool to remove the back cover.
    • Be careful not to damage the ribbon cable connecting the back cover to the laptop.
  3. Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the (2) two 3mm J0 Phillips head screws that hold the battery in place.
  4. Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery from the motherboard.
    • Carefully disconnect the cable parallel to the board, not at an angle. Otherwise, you could damage the port.
  5. Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 5, afbeelding 2 van 2
    • Carefully lift the battery from one side, and then lift it out of the laptop.
  6. Acer Chromebook CB3-131-C3KD Track pad Replacement, Trackpad: stap 6, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Track pad Replacement, Trackpad: stap 6, afbeelding 2 van 2
    • Remove the (3) three 7.0mm screws using the J0 screwdriver head.
  7. Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 7, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 7, afbeelding 2 van 2
    • Unlock the latches on both ends of the ribbon cable, and pull to detach.
    • The ribbon cable will still be attached to the tape.
  8. Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 8, afbeelding 1 van 1
    • Peel the tape that is on top of the trackpad.
  9. Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 9, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: stap 9, afbeelding 2 van 2
    • Lift the trackpad out of the Chromebook.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ashley Oxner
704 Reputatie
3 handleidingen geschreven
USF Tampa, Team S11-G1, Passmore Fall 2017 Lid van USF Tampa, Team S11-G1, Passmore Fall 2017
USFT-PASSMORE-F17S11G1
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 401
