Ga door naar hoofdinhoud
Acer Chromebook CB3-131-C3KD Speakers Replacement
Wat je nodig hebt
  1. Acer Chromebook CB3-131-C3KD Speakers Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Speakers Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure you turn off the laptop before starting.
    • Unscrew and remove the (11) eleven 4mm J0 head screws on the underside of the laptop using the JIS #0 screwdriver.
  2. Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 2, afbeelding 1 van 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 2, afbeelding 2 van 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 2, afbeelding 3 van 3
    • Use the plastic opening tool to remove the back cover.
    • Be careful not to damage the ribbon cable connecting the back cover to the laptop.
  3. Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the (2) two 3mm J0 Phillips head screws that hold the battery in place.
  4. Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery from the motherboard.
    • Carefully disconnect the cable parallel to the board, not at an angle. Otherwise, you could damage the port.
  5. Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 5, afbeelding 2 van 2
    • Carefully lift the battery from one side, and then lift it out of the laptop.
  6. Acer Chromebook CB3-131-C3KD Speakers Replacement, Speakers: stap 6, afbeelding 1 van 3 Acer Chromebook CB3-131-C3KD Speakers Replacement, Speakers: stap 6, afbeelding 2 van 3 Acer Chromebook CB3-131-C3KD Speakers Replacement, Speakers: stap 6, afbeelding 3 van 3
    • Disconnect the three ribbon cables from the motherboard.
  7. Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 7, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 7, afbeelding 2 van 2
    • Unplug the cable by putting both thumbs on each tab and unlocking the cable by pushing the tabs away.
  8. Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 8, afbeelding 1 van 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 8, afbeelding 2 van 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 8, afbeelding 3 van 3
    • Remove speakers by placing index finger on top and thumb on bottom of the speakers.
    • Peel speakers away from the base that is connected by an adhesive.
  9. Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 9, afbeelding 1 van 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 9, afbeelding 2 van 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: stap 9, afbeelding 3 van 3
    • Peel the black cord connecting the two speakers together away from the Velcro located at the midpoint between the two speakers.
    • Remove speakers from laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Johnathan
216 Reputatie
2 handleidingen geschreven
USF Tampa, Team S11-G1, Passmore Fall 2017 Lid van USF Tampa, Team S11-G1, Passmore Fall 2017
USFT-PASSMORE-F17S11G1
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 348
