Ga door naar hoofdinhoud
Acer Chromebook CB3-131-C3KD Motherboard Replacement
Wat je nodig hebt
  1. Acer Chromebook CB3-131-C3KD Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure you turn off the laptop before starting.
    • Unscrew and remove the (11) eleven 4mm J0 head screws on the underside of the laptop using the JIS #0 screwdriver.
  2. Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 2, afbeelding 1 van 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 2, afbeelding 2 van 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Use the plastic opening tool to remove the back cover.
    • Be careful not to damage the ribbon cable connecting the back cover to the laptop.
  3. Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the (2) two 3mm J0 Phillips head screws that hold the battery in place.
  4. Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery from the motherboard.
    • Carefully disconnect the cable parallel to the board, not at an angle. Otherwise, you could damage the port.
  5. Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Carefully lift the battery from one side, and then lift it out of the laptop.
  6. Acer Chromebook CB3-131-C3KD Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Unscrew the (4) four J0 head 3.0 mm screws from the motherboard.
    • Unscrew the (1) one 7.0 mm screw from the center of the motherboard.
  7. Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 7, afbeelding 1 van 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 7, afbeelding 2 van 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Unlock the latches on the three white ribbon cables, then pull to detach them from the motherboard.
    • Slide the hook forward and pull the black ribbon cable out.
  8. Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 8, afbeelding 1 van 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 8, afbeelding 2 van 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Unscrew the 4.0 mm screw from the Wi-fi card using the JIS #0 screwdriver.
    • Pull the Wi-fi card parallel to the Chromebook to remove.
  9. Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 9, afbeelding 1 van 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 9, afbeelding 2 van 3 Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 9, afbeelding 3 van 3
    • To remove the regular cable near the hinge, pry from one side.
    • To remove the regular cable at the top of the motherboard, pull it parallel to the board.
  10. Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 10, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Open the hinge by prying it backwards.
    • Remove the motherboard by lifting from the top.
Conclusie
Ashley Oxner
704 Reputatie
3 handleidingen geschreven
USF Tampa, Team S11-G1, Passmore Fall 2017 Lid van USF Tampa, Team S11-G1, Passmore Fall 2017
USFT-PASSMORE-F17S11G1
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 25
Altijd: 1,155
