Ga door naar hoofdinhoud
Acer Chromebook CB3-131-C3KD Keyboard Key Replacement
Wat je nodig hebt
  1. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement, Keyboard Key: stap 1, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Keyboard Key Replacement, Keyboard Key: stap 1, afbeelding 2 van 2
    • Make sure you turn off the laptop before starting.
    • Place the flat head screw driver under the key, but over the key clip retainer.
  2. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: stap 2, afbeelding 1 van 1
    • Push down on one of the bottom corners of the key, so that the opposite diagonal corner rises and gives leeway.
    • Carefully place the flat head screw driver under the raised corner.
    • Carefully pry up from underneath the raised corner to raise the metal clips away from the key base.
  3. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: stap 3, afbeelding 2 van 2
    • Pry up from the top left and right corners of the retainer subsequently.
    • Remove clip retainer.
Conclusie
Johnathan
216 Reputatie
2 handleidingen geschreven
USF Tampa, Team S11-G1, Passmore Fall 2017 Lid van USF Tampa, Team S11-G1, Passmore Fall 2017
USFT-PASSMORE-F17S11G1
3 Leden
10 handleidingen geschreven
Één opmerking
I mean… That’s half of the replacement… so there’s that.
Darren D. MacDonald - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 1,511
