Ga door naar hoofdinhoud
Acer Chromebook CB3-111-C670 Screen Replacement
Wat je nodig hebt
  1. Acer Chromebook CB3-111-C670 Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Acer Chromebook CB3-111-C670 Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • Unplug and power off the laptop before starting this repair.
    • Pry the white frame away from the screen with an opening tool.
    • As you move the spudger along the seam between the frame and the screen, the clips holding the frame in place will loosen.
  2. Acer Chromebook CB3-111-C670 Screen Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook CB3-111-C670 Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the four screws within the silver brackets that are holding the screen to the back of the laptop.
  3. Acer Chromebook CB3-111-C670 Screen Replacement: stap 3, afbeelding 1 van 1
    • Once you've removed the screws, lift the piece of tape that is covering the display connector.
    • Use a spudger to flip up the black tab on top of the connector to unlock the ZIF connector.
  4. Acer Chromebook CB3-111-C670 Screen Replacement: stap 4, afbeelding 1 van 1
    • Pull the ribbon cable out with tweezers and remove the screen.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Allen Lewis
259 Reputatie
1 Handleiding geschreven
USF Tampa, Team 10-5, Remmell Spring 2016 Lid van USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Leden
8 handleidingen geschreven
Één opmerking
Very easy. Thanks
johnqm123 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 4,974
