Ga door naar hoofdinhoud
Acer Chromebook CB3-111-C670 Keyboard Key Replacement
Wat je nodig hebt
  1. Acer Chromebook CB3-111-C670 Keyboard Key Replacement, Keyboard Key: stap 1, afbeelding 1 van 1
    • Remove broken key(s) using the flat end of spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular spudger and tweezer should be used whenever possible.
    • When reinstalling the key, no spudger is needed. Just pop it into place with fingers.
  2. Acer Chromebook CB3-111-C670 Keyboard Key Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook CB3-111-C670 Keyboard Key Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using the flat end of the spudger, very carefully lift up the corners of the cradle.
    • With the help of tweezers (needle nose works best), pull the hooks of the cradle out.
    • For re-installation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Tony
459 Reputatie
2 handleidingen geschreven
USF Tampa, Team 10-5, Remmell Spring 2016 Lid van USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Leden
8 handleidingen geschreven
Één opmerking
no help i need help putting it on with out that
Simon Kuhn - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 60
Altijd: 7,391
