Ga door naar hoofdinhoud
Acer Chromebook C740-C4PE Touchpad Replacement
Wat je nodig hebt
  1. Acer Chromebook C740-C4PE Touchpad Replacement, Battery: stap 1, afbeelding 1 van 3 Acer Chromebook C740-C4PE Touchpad Replacement, Battery: stap 1, afbeelding 2 van 3 Acer Chromebook C740-C4PE Touchpad Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Touchpad Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Touchpad Replacement: stap 3, afbeelding 1 van 1
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Touchpad Replacement: stap 4, afbeelding 1 van 3 Acer Chromebook C740-C4PE Touchpad Replacement: stap 4, afbeelding 2 van 3 Acer Chromebook C740-C4PE Touchpad Replacement: stap 4, afbeelding 3 van 3
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
  5. Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: stap 5, afbeelding 1 van 2 Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: stap 5, afbeelding 2 van 2
    • Unscrew the two screws on the silver restraint with the Phillips #0 screwdriver.
    • Lift the silver restraint from the device.
  6. Acer Chromebook C740-C4PE Touchpad Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the five screws on the touchpad.
    • You will need to move aside the plastic covering that is above each screw.
  7. Acer Chromebook C740-C4PE Touchpad Replacement: stap 7, afbeelding 1 van 2 Acer Chromebook C740-C4PE Touchpad Replacement: stap 7, afbeelding 2 van 2
    • Using a spudger, lift the black electrical tape to the left of the touchpad.
    • Remove the black wire running across the touchpad from the two hooks on top of the part.
    • Be careful not to damage the black wire when removing from the two hooks.
  8. Acer Chromebook C740-C4PE Touchpad Replacement: stap 8, afbeelding 1 van 2 Acer Chromebook C740-C4PE Touchpad Replacement: stap 8, afbeelding 2 van 2
    • Lift the flap on the wire connecting the motherboard and remove the connector.
  9. Acer Chromebook C740-C4PE Touchpad Replacement: stap 9, afbeelding 1 van 1
    • Remove the touchpad from the device.
Conclusie
Jacob Kahn
273 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 Lid van UMass Dartmouth, Team S6-G4, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G4
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 293
