Ga door naar hoofdinhoud
Acer Chromebook C740-C4PE Solid State Drive Replacement
Wat je nodig hebt
  1. Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: stap 1, afbeelding 1 van 3 Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: stap 1, afbeelding 2 van 3 Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: stap 1, afbeelding 3 van 3
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the 13 screws on the back of the device using a PH0 Phillips head screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Solid State Drive Replacement: stap 2, afbeelding 1 van 3 Acer Chromebook C740-C4PE Solid State Drive Replacement: stap 2, afbeelding 2 van 3 Acer Chromebook C740-C4PE Solid State Drive Replacement: stap 2, afbeelding 3 van 3
    • Remove the 3.75 mm screw with a Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Solid State Drive Replacement: stap 3, afbeelding 1 van 1
    • Pull the Solid State Drive out of the connector.
Conclusie
Sang Huynh
252 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 Lid van UMass Dartmouth, Team S6-G4, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G4
3 Leden
12 handleidingen geschreven
Één opmerking
There are 2 types of SSD drives, m-SATA and M.2. Which does C740 use?
Guy Scree - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 753
