Ga door naar hoofdinhoud
Acer Chromebook C740-C4PE Heatsink Replacement
Wat je nodig hebt
  1. Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: stap 1, afbeelding 1 van 3 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: stap 1, afbeelding 2 van 3 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: stap 1, afbeelding 3 van 3
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Heatsink Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook C740-C4PE Heatsink Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 5mm screws on the heatsink using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Heatsink Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook C740-C4PE Heatsink Replacement: stap 3, afbeelding 2 van 2
    • Loosen the two Phillips-head screws on the fan attached to the heatsink.
  4. Acer Chromebook C740-C4PE Heatsink Replacement: stap 4, afbeelding 1 van 1
    • Detach the two antennae cables from the WiFi card by gently pulling on them.
  5. Acer Chromebook C740-C4PE Heatsink Replacement: stap 5, afbeelding 1 van 1
    • Gently pull the fan cable out of the motherboard.
    • Pulling too hard may break the wires or the connector itself.
  6. Acer Chromebook C740-C4PE Heatsink Replacement: stap 6, afbeelding 1 van 1
    • Remove the cable routed through the fan.
    • Do not completely remove the cables as they are attached to the motherboard. Once they are no longer routed in the fan, leave them as they are.
  7. Acer Chromebook C740-C4PE Heatsink Replacement: stap 7, afbeelding 1 van 1
    • Remove the heatsink from the motherboard.
    • Before changing the heatsink/fan, you must clean off the thermal paste from the CPU and apply new thermal paste.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dylan Tocci
237 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 Lid van UMass Dartmouth, Team S6-G4, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G4
3 Leden
12 handleidingen geschreven
Één opmerking
What type of thermal paste is best used?
Tracey Arria - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 356
