Ga door naar hoofdinhoud
Acer Chromebook C740-C4PE Battery Replacement
Wat je nodig hebt
  1. Acer Chromebook C740-C4PE Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Acer Chromebook C740-C4PE Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Acer Chromebook C740-C4PE Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Battery Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Battery Replacement: stap 3, afbeelding 1 van 1
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Battery Replacement: stap 4, afbeelding 1 van 3 Acer Chromebook C740-C4PE Battery Replacement: stap 4, afbeelding 2 van 3 Acer Chromebook C740-C4PE Battery Replacement: stap 4, afbeelding 3 van 3
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jacob Kahn
273 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 Lid van UMass Dartmouth, Team S6-G4, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G4
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 479
