Ga door naar hoofdinhoud
Acer Chromebook C740 LCD Screen Replacement
Wat je nodig hebt
  1. Acer Chromebook C740 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 LCD Screen Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook C740 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • With the Chromebook open and face up, pry the black screen frame with your fingers.
    • Move slowly around the display to evenly remove it.
    • Clicking sounds indicate the panel is seperating from the overall display.
  3. Acer Chromebook C740 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Once the frame is separated from the display, angle the display assembly back .
    • Lift up the portions of the frame covering the front two hinges with the spudger.
  4. Acer Chromebook C740 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the frame from the screen assembly by pulling the frame towards you.
    • Some adjustment of the display assembly may be needed so that the frame is not stuck near the hinges.
  5. Acer Chromebook C740 LCD Screen Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook C740 LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Remove the six 3.35mm screws with a Phillips #0 Screwdriver.
  6. Acer Chromebook C740 LCD Screen Replacement: stap 6, afbeelding 1 van 3 Acer Chromebook C740 LCD Screen Replacement: stap 6, afbeelding 2 van 3 Acer Chromebook C740 LCD Screen Replacement: stap 6, afbeelding 3 van 3
    • Place the LCD screen face down on the keyboard.
    • Remove the tape holding the black connector in place.
    • Unplug the connector with your hands.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Grace Bassett
217 Reputatie
1 Handleiding geschreven
Cal Poly, Team S22-G2, Livingston Spring 2017 Lid van Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 Leden
12 handleidingen geschreven
Één opmerking
You actually don’t need to unscrew the middle screws, and you don’t need to buy a new bezel.
Keith Hudson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 3,305
