Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Power down the Chromebook and disconnect the power adapter.
Place the chromebook bottom side up on a flat surface.
Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
Remove the the two 3.7 mm screws with a Phillips #0 screwdriver.
7 andere personen hebben deze handleiding voltooid.
