Ga door naar hoofdinhoud
Acer Chromebook C740 Battery Replacement
Wat je nodig hebt
  1. Acer Chromebook C740 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 Battery Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook C740 Battery Replacement: stap 2, afbeelding 2 van 2
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
  3. Acer Chromebook C740 Battery Replacement: stap 3, afbeelding 1 van 3 Acer Chromebook C740 Battery Replacement: stap 3, afbeelding 2 van 3 Acer Chromebook C740 Battery Replacement: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
  4. Acer Chromebook C740 Battery Replacement, Battery: stap 4, afbeelding 1 van 3 Acer Chromebook C740 Battery Replacement, Battery: stap 4, afbeelding 2 van 3 Acer Chromebook C740 Battery Replacement, Battery: stap 4, afbeelding 3 van 3
    • Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
    • The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
  5. Acer Chromebook C740 Battery Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook C740 Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the the two 3.7 mm screws with a Phillips #0 screwdriver.
  6. Acer Chromebook C740 Battery Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery from the frame.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Flor De La Rosa
875 Reputatie
4 handleidingen geschreven
Cal Poly, Team S22-G2, Livingston Spring 2017 Lid van Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 7,581
