Ga door naar hoofdinhoud
Inleiding
Prerequisite Only
  1. Power down the Chromebook and disconnect the power adapter.
    • Power down the Chromebook and disconnect the power adapter.
  2. Place the chromebook bottom side up on a flat surface. Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
  3. Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel. Applying pressure may be necessary. A click indicates the panel is ready to come off. Applying pressure may be necessary. A click indicates the panel is ready to come off.
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
Conclusie
Flor De La Rosa
817 Reputatie
4 handleidingen geschreven
Cal Poly, Team S22-G2, Livingston Spring 2017 Lid van Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 Leden
12 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 52
