Ga door naar hoofdinhoud
Acer Chromebook C732 Battery Replacement
Wat je nodig hebt
  1. Acer Chromebook C732 Battery Replacement, Opening up your device: stap 1, afbeelding 1 van 2 Acer Chromebook C732 Battery Replacement, Opening up your device: stap 1, afbeelding 2 van 2
    • Flip the computer over, and using a Phillips #1 screwdriver, remove all 12 bottom cover screws.
    • Once all the screws are removed, place both pointer fingers between the screen hinges and the case and carefully pry the case away from the hinges.
  2. Acer Chromebook C732 Battery Replacement, Remove the ESD tape: stap 2, afbeelding 1 van 2 Acer Chromebook C732 Battery Replacement, Remove the ESD tape: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Once the back cover is removed, you will see that the battery is only held in place with a piece of ESD Tape. Using a set of tweezers, carefully peel away the tape from one end.
  3. Acer Chromebook C732 Battery Replacement, Disconnect your battery: stap 3, afbeelding 1 van 1
    • Once the tape is removed, you can use the pointed end of a Spudger or your fingernails and carefully unplug the battery from the logic board.
  4. Acer Chromebook C732 Battery Replacement, Remove your old battery: stap 4, afbeelding 1 van 1
    • The battery can now be removed.
    • To install the new battery, follow these steps in reverse order.
Conclusie
The device will be in a battery disconnected state. This means that the device will not simply power on once the battery is reconnected. To bring the device out of storage mode, plug the device into a charger and a power source. You can then power on the device like normal.
3 andere personen hebben deze handleiding voltooid.
Jacob Mehnert
38.641 Reputatie
50 handleidingen geschreven
iFanatics Lid van iFanatics
Community
60 Leden
191 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 25
Altijd: 623
