Ga door naar hoofdinhoud
Acer Chromebook C731-C8VE Display Assembly Replacement
Wat je nodig hebt
  1. Acer Chromebook C731-C8VE Display Assembly Replacement, Display Assembly: stap 1, afbeelding 1 van 1
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Display Assembly Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook C731-C8VE Display Assembly Replacement: stap 2, afbeelding 2 van 2
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • The 2 mm screws marked orange have washers attached and must be placed in these specific areas.
    • These 2 mm screws do not have washers and will be located on the left and right of the device.
  3. Acer Chromebook C731-C8VE Display Assembly Replacement: stap 3, afbeelding 1 van 3 Acer Chromebook C731-C8VE Display Assembly Replacement: stap 3, afbeelding 2 van 3 Acer Chromebook C731-C8VE Display Assembly Replacement: stap 3, afbeelding 3 van 3
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Display Assembly Replacement: stap 4, afbeelding 1 van 3 Acer Chromebook C731-C8VE Display Assembly Replacement: stap 4, afbeelding 2 van 3 Acer Chromebook C731-C8VE Display Assembly Replacement: stap 4, afbeelding 3 van 3
    • Use the JIS #00 screwdriver to remove the four 1.5mm screws that connect the base of the laptop to the screen. There are two screws on each latch.
    • Carefully detach the cables that connect the screen to the motherboard. This includes a black display cable that connects to the mother board and two wires that connect to the Wi-Fi card.
  5. Acer Chromebook C731-C8VE Display Assembly Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook C731-C8VE Display Assembly Replacement: stap 5, afbeelding 2 van 2
    • Do this step slowly to ensure that you do not damage the screen or the motherboard.
    • Remove the screen from the base of the device.
Conclusie
Justin Menninger
385 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 270
