Ga door naar hoofdinhoud
Acer Chromebook C731-C8VE Battery Replacement
Wat je nodig hebt
  1. Acer Chromebook C731-C8VE Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Battery Replacement: stap 2, afbeelding 1 van 1
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and will be located on the left and right of the device.
    • The 2 mm screws marked orange do not have washers attached and must be placed in these specific areas.
  3. Acer Chromebook C731-C8VE Battery Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook C731-C8VE Battery Replacement: stap 3, afbeelding 2 van 2
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Battery Replacement: stap 4, afbeelding 1 van 3 Acer Chromebook C731-C8VE Battery Replacement: stap 4, afbeelding 2 van 3 Acer Chromebook C731-C8VE Battery Replacement: stap 4, afbeelding 3 van 3
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE Battery Replacement: stap 5, afbeelding 1 van 3 Acer Chromebook C731-C8VE Battery Replacement: stap 5, afbeelding 2 van 3 Acer Chromebook C731-C8VE Battery Replacement: stap 5, afbeelding 3 van 3
    • Use the JIS #00 screwdriver to take out the 1mm screw that connects the battery to the base.
    • Detach the battery from the motherboard by lifting it up gently to avoid any damage to the motherboard.
  6. Acer Chromebook C731-C8VE Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery from the base of the device.
    • Do this step slowly to ensure that you do not damage the battery or the motherboard.
Conclusie
Jackson Bryant
233 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 323
