Ga door naar hoofdinhoud
Acer Chromebook C730-C4V9 Keyboard Replacement
Wat je nodig hebt
  1. Acer Chromebook C730-C4V9 Keyboard Replacement, Rear Cover: stap 1, afbeelding 1 van 2 Acer Chromebook C730-C4V9 Keyboard Replacement, Rear Cover: stap 1, afbeelding 2 van 2
    • Be sure to have completely shut down the device before attempting to open it.
    • Flip the device over and remove the twelve screws.
    • Using a spudger slowly pry the case open by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Be careful when removing the cover off the device, a ribbon cable is connected to it
  2. Acer Chromebook C730-C4V9 Keyboard Replacement, Ribbon Cable: stap 2, afbeelding 1 van 1
    • Remove the USB Ribbon cable by opening the connector on the motherboard and sliding the cable out.
  3. Acer Chromebook C730-C4V9 Keyboard Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the two screws on the sides of the battery.
    • Carefully slide the battery forward and the lift up
    • Unplug the battery from the motherboard to prevent shortages.
  4. Acer Chromebook C730-C4V9 Keyboard Replacement, Wi-Fi Chip: stap 4, afbeelding 1 van 2 Acer Chromebook C730-C4V9 Keyboard Replacement, Wi-Fi Chip: stap 4, afbeelding 2 van 2
    • Remove the screw from the Wi-Fi chip
    • Unplug the aerials
    • Remember the order of the aerials! (Generally black then white)
    • Slide the chip away from the motherboard
  5. Acer Chromebook C730-C4V9 Keyboard Replacement, Motherboard Cables: stap 5, afbeelding 1 van 1
    • Remove the screen cable by using the tab and pulling up.
    • Remove the track pad cable by opening the connector and sliding the cable away from the motherboard.
    • Remove the keyboard cable by opening the connector and sliding it away from the motherboard.
    • The speaker cable can be a bit tricky, with the assistance of the plastic opening tool, pull/pry the plug towards you (Carefully!)
  6. Acer Chromebook C730-C4V9 Keyboard Replacement, Hinges: stap 6, afbeelding 1 van 2 Acer Chromebook C730-C4V9 Keyboard Replacement, Hinges: stap 6, afbeelding 2 van 2
    • Remove the six screws from the hinges.
  7. Acer Chromebook C730-C4V9 Keyboard Replacement, Motherboard: stap 7, afbeelding 1 van 2 Acer Chromebook C730-C4V9 Keyboard Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Using the plastic opening tool, slide it under the right hinge and lift the hinge up so its not sitting on the motherboard.
    • Remove the five screws holding the motherboard in.
    • Lift the motherboard up slowly.
    • Try to lift the motherboard up as straight as possible as there is solid thermal grease on the bottom.
  8. Acer Chromebook C730-C4V9 Keyboard Replacement, Speakers: stap 8, afbeelding 1 van 1
    • Using the plastic opening tool, insert it under the speakers in the middle and pry them up
    • The speakers are held on with double sided tape and will be glued back later. (You can use double sided tape if you wish)
  9. Acer Chromebook C730-C4V9 Keyboard Replacement, Remove Screen (Optional): stap 9, afbeelding 1 van 2 Acer Chromebook C730-C4V9 Keyboard Replacement, Remove Screen (Optional): stap 9, afbeelding 2 van 2
    • This step is optional, I do it because it makes life so much easier!! But its totally up to you.
    • While holding your thumbs on the hinges to keep them in place, open the screen slowly
    • Once the screen is almost flat you should feel the hinges come loose.
    • Lift the screen up from the body and it should separate.
  10. Acer Chromebook C730-C4V9 Keyboard Replacement, Remove plastic pins: stap 10, afbeelding 1 van 3 Acer Chromebook C730-C4V9 Keyboard Replacement, Remove plastic pins: stap 10, afbeelding 2 van 3 Acer Chromebook C730-C4V9 Keyboard Replacement, Remove plastic pins: stap 10, afbeelding 3 van 3
    • The motherboard plate is held onto the frame by plastic pins.
    • Work your way along the edges of the plate and attempt to remove the top off every single pen if possible.
  11. Acer Chromebook C730-C4V9 Keyboard Replacement, Remove Plate: stap 11, afbeelding 1 van 2 Acer Chromebook C730-C4V9 Keyboard Replacement, Remove Plate: stap 11, afbeelding 2 van 2
    • After removing as many pins as possible work your way around the plate and pry it up.
    • Start working your way under the plate to disconnect it from the keyboard.
  12. Acer Chromebook C730-C4V9 Keyboard Replacement, Remove Keyboard: stap 12, afbeelding 1 van 3 Acer Chromebook C730-C4V9 Keyboard Replacement, Remove Keyboard: stap 12, afbeelding 2 van 3 Acer Chromebook C730-C4V9 Keyboard Replacement, Remove Keyboard: stap 12, afbeelding 3 van 3
    • The keyboard is held onto the frame by plastic pins.
    • Work your way along the edges of the keyboard and attempt to remove the top off every single pen if possible.
    • Do not cut the pins that stick out above the keyboard, these are for the motherboard plate.
    • After you have removed the top off every pin, using the plastic opening tool work your way around the keyboard, it should lift right out.
  13. Acer Chromebook C730-C4V9 Keyboard Replacement, Secure Keyboard: stap 13, afbeelding 1 van 3 Acer Chromebook C730-C4V9 Keyboard Replacement, Secure Keyboard: stap 13, afbeelding 2 van 3 Acer Chromebook C730-C4V9 Keyboard Replacement, Secure Keyboard: stap 13, afbeelding 3 van 3
    • Place the new keyboard in the frame and ensure it is sitting nicely.
    • Once in place, using a hot glue gun start putting small drops of glue on the pins you cut off the keyboard.
    • While gluing, keep a constant pressure on the keyboard to ensure it sets while in its optimal position!
    • Avoid gluing the pins that are risen! This will affect the fitment of the motherboard plate.
    • Do NOT put glue in the keyboard holes that haven't got pins! These holes will leak glue underneath the keys! ONLY place glue on the keyboard pins
  14. Acer Chromebook C730-C4V9 Keyboard Replacement, Secure Motherboard Plate: stap 14, afbeelding 1 van 2 Acer Chromebook C730-C4V9 Keyboard Replacement, Secure Motherboard Plate: stap 14, afbeelding 2 van 2
    • Work your way around the plate putting glue on the plastic pins.
    • While gluing, keep a constant pressure on the plate to ensure it sets while in its optimal position!
    • Only put glue on the plastic pins you cut the tops off!
  15. Acer Chromebook C730-C4V9 Keyboard Replacement, Secure Speakers: stap 15, afbeelding 1 van 1
    • Chose whether to use glue or double sided tape.
    • Put a dab of glue at the top and bottom of the speaker (Where the old double sided tape is)
    • Place speaker into position.
Conclusie
Dylan Baldwin
351 Reputatie
1 Handleiding geschreven
Één opmerking
Your detailed and well explained instructions have let me replace the keyboard with success. So many thanks!!!!!
pablofcid - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 1,542
