Ga door naar hoofdinhoud
Acer Chromebook C720-2848 Battery Replacement
Wat je nodig hebt
  1. Acer Chromebook C720-2848 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 2 Acer Chromebook C720-2848 Battery Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Use a Phillips head screw driver to remove the 13 screws in these locations.
  2. Acer Chromebook C720-2848 Battery Replacement: stap 2, afbeelding 1 van 3 Acer Chromebook C720-2848 Battery Replacement: stap 2, afbeelding 2 van 3 Acer Chromebook C720-2848 Battery Replacement: stap 2, afbeelding 3 van 3
    • Use a plastic spudger to pry up the bottom cover and remove it.
    • Be sure to pry along other edges if necessary to avoid damaging the back cover.
  3. Acer Chromebook C720-2848 Battery Replacement, Battery: stap 3, afbeelding 1 van 3 Acer Chromebook C720-2848 Battery Replacement, Battery: stap 3, afbeelding 2 van 3 Acer Chromebook C720-2848 Battery Replacement, Battery: stap 3, afbeelding 3 van 3
    • Unscrew the 2 battery screws.
    • Make sure you keep these screws separate from the back cover screws; they are different!
  4. Acer Chromebook C720-2848 Battery Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook C720-2848 Battery Replacement: stap 4, afbeelding 2 van 2
    • Use two fingers to unplug the battery-to-motherboard connection.
  5. Acer Chromebook C720-2848 Battery Replacement: stap 5, afbeelding 1 van 1
    • Take out battery by lifting it up in the manner pictured.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Robert Escobio
597 Reputatie
4 handleidingen geschreven
USF Tampa, Team S9-G3, Remmell Fall 2017 Lid van USF Tampa, Team S9-G3, Remmell Fall 2017
USFT-REMMELL-F17S9G3
4 Leden
9 handleidingen geschreven
3 opmerkingen
How do you know if the battery needs to be replaced
1910.julius - Antwoord
You will know if the battery needs to be replaced if your chromebook goes dead rather quickly than it used to or if you open it up and see that your bettery is bulged or appears to be inflated then if will also need to be replaced. I hope this helps.
Ashton Vandenbosch -
My Acer C720 Chromebook battery only charges to about 30-40% percent no matter how long I leave it on charger. Sometimes (randomly) it doesn’t charge at all. How do I diagnose whether I need to replace the charging port, the charging cord or the battery?
Bart Stinson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 2,803
