Ga door naar hoofdinhoud
Acer Chromebook C720-2848 Screen Replacement
Wat je nodig hebt
  1. Acer Chromebook C720-2848  Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Acer Chromebook C720-2848  Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • Insert a metal spudger around the inner side of the screens plastic perimeter.
    • Move along the perimeter while leveraging to pop the faceplate out like so.
  2. Acer Chromebook C720-2848  Screen Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook C720-2848  Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the faceplate's bottom hinges that connect to the body of the device with the metal spudger. This will free the plastic perimeter, which may now be removed.
  3. Acer Chromebook C720-2848  Screen Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the 6 screws in these circled locations.
  4. Acer Chromebook C720-2848  Screen Replacement: stap 4, afbeelding 1 van 1
    • Reposition so the screen will lay flat on the keyboard of the laptop.
  5. Acer Chromebook C720-2848  Screen Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook C720-2848  Screen Replacement: stap 5, afbeelding 2 van 2
    • Locate the bar code adhesion strip at the base of the screen, and then peel it back carefully. Once peeled back the plug-in will come free.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Cory Provost
212 Reputatie
1 Handleiding geschreven
USF Tampa, Team S9-G3, Remmell Fall 2017 Lid van USF Tampa, Team S9-G3, Remmell Fall 2017
USFT-REMMELL-F17S9G3
4 Leden
9 handleidingen geschreven
Één opmerking
In step 2, "the faceplate's bottom hinges" are plastic hinge covers that are (or, at least, were) part of the bezel. You may be able to take the bezel off while they're still attached, or you may have to break the flexing points so that they come off separately. Either way, it doesn't seem to cause a problem.
Thanks, Cory.
Lance ==)--------------
Lance - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 1,722
