Ga door naar hoofdinhoud
Acer Chromebook C720-2827 Trackpad Replacement
Wat je nodig hebt
  1. Acer Chromebook C720-2827 Trackpad Replacement, Back Panel Assembly: stap 1, afbeelding 1 van 2 Acer Chromebook C720-2827 Trackpad Replacement, Back Panel Assembly: stap 1, afbeelding 2 van 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 Trackpad Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook C720-2827 Trackpad Replacement: stap 2, afbeelding 2 van 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 Trackpad Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 Trackpad Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook C720-2827 Trackpad Replacement: stap 4, afbeelding 2 van 2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 Trackpad Replacement: stap 5, afbeelding 1 van 1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: stap 6, afbeelding 1 van 3 Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: stap 6, afbeelding 2 van 3 Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: stap 6, afbeelding 3 van 3
    • Using a spudger, pry up the locking bar of the ZIF connector on the trackpad and remove the ribbon cable.
  7. Acer Chromebook C720-2827 Trackpad Replacement: stap 7, afbeelding 1 van 3 Acer Chromebook C720-2827 Trackpad Replacement: stap 7, afbeelding 2 van 3 Acer Chromebook C720-2827 Trackpad Replacement: stap 7, afbeelding 3 van 3
    • Peel off the clear plastic covering the screws.
    • Remove the five grey 2.5 mm screws securing the trackpad with a Phillips #1 screwdriver.
    • Remove another four silver 2.9mm Phillips #1 screws from the silver bracket atop the trackpad with your driver.
  8. Acer Chromebook C720-2827 Trackpad Replacement: stap 8, afbeelding 1 van 2 Acer Chromebook C720-2827 Trackpad Replacement: stap 8, afbeelding 2 van 2
    • Lift up the silver bracket.
    • Remove the trackpad by lifting it up from the case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Austin Blakely
21.315 Reputatie
53 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.585 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 271
