Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
Pry the back panel open with the plastic opening tool.
Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
Carefully pull out the battery wire connected to the battery port.
Slowly lift the battery to remove it from the Chromebook.
Carefully pull out the speakers from each side of the Chromebook.
Remove the three 6.0mm screws using the Phillips #1 screwdriver.
Remove the two 3.0mm screws using the Phillips #1 screwdriver.
Position the spudger under the switch that connects the ribbon cable to the motherboard.
Flick the spudger up to flip the switch up.
Pull the blue tab on the ribbon cable to remove it.
Grab the edges of each piece of circuitry that is included with the SD Card Reader and USB Port.
Pull each piece of circuitry out of the Chromebook and remove it from the device.
Position the spudger under the switch.
Pull on the blue tab of the ribbon cable to remove the ribbon cable.
Repeat the previous step and this step with the other ribbon cable that is attached to the SD Card Reader/USB Port.
Één andere persoon heeft deze handleiding voltooid.
