Ga door naar hoofdinhoud
Acer Chromebook C720-2827 LED PCB Replacement
Wat je nodig hebt
  1. Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: stap 1, afbeelding 1 van 2 Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: stap 1, afbeelding 2 van 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 LED PCB Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook C720-2827 LED PCB Replacement: stap 2, afbeelding 2 van 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 LED PCB Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 LED PCB Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook C720-2827 LED PCB Replacement: stap 4, afbeelding 2 van 2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 LED PCB Replacement: stap 5, afbeelding 1 van 1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: stap 6, afbeelding 1 van 3 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: stap 6, afbeelding 2 van 3 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: stap 6, afbeelding 3 van 3
    • Use the Phillips #1 screwdriver to remove the two 3.1mm screws from the LED PCB.
    • Lift the LED PCB up with your fingers and flip it over revealing the ZIF connector.
    • The LED PCB is still tethered to the daughterboard via a ribbon cable so be sure not to yank it out or it could cause damage to the cable or its connectors.
  7. Acer Chromebook C720-2827 LED PCB Replacement: stap 7, afbeelding 1 van 3 Acer Chromebook C720-2827 LED PCB Replacement: stap 7, afbeelding 2 van 3 Acer Chromebook C720-2827 LED PCB Replacement: stap 7, afbeelding 3 van 3
    • Set the LED PCB down and use your spudger to flip up the white bar of the ZIF connector.
    • Pull the ribbon cable out with your fingers.
Conclusie
Sarah Westberg
23.043 Reputatie
70 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.734 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 230
