Inleiding
This guide goes through the steps on how to replace the solid state drive for the Acer Chromebook C720-2103. This is a fairly easy replacement guide and only need the knowledge for the use of a Phillips screwdriver. The main part of the replacement guide is removing screws, the battery and the actual part. There is also a removable of one simple cable. Make sure the device is powered off during this replacement as there is a possibility of electrocution.
Wat je nodig hebt
Shut the device off.
Turn the device over so the bottom is facing up.
Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
