Ga door naar hoofdinhoud
Acer Chromebook C720 Solid State Drive (SSD) Replacement
Wat je nodig hebt
  1. Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): stap 1, afbeelding 1 van 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): stap 1, afbeelding 2 van 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): stap 1, afbeelding 3 van 3
    • WARNING: Make sure your device is turned off before proceeding. If you proceed with the device on, the device may be damaged
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Using the blue plastic case opener, unlatch the back of the case to expose the motherboard and other components.
  2. Acer Chromebook C720 Solid State Drive (SSD) Replacement: stap 2, afbeelding 1 van 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement: stap 2, afbeelding 2 van 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement: stap 2, afbeelding 3 van 3
    • Remove the single 3mm screw holding the SSD with the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Solid State Drive (SSD) Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook C720 Solid State Drive (SSD) Replacement: stap 3, afbeelding 2 van 2
    • Gently remove the SSD from the motherboard.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Benjamin Rahman
517 Reputatie
3 handleidingen geschreven
IUPUI, Team S2-G5, Harley Spring 2019 Lid van IUPUI, Team S2-G5, Harley Spring 2019
IUPUI-HARLEY-S19S2G5
4 Leden
7 handleidingen geschreven
2 opmerkingen
When you’re looking for a replacement drive, its socket is for a B-keyed m.2 2242 (22m x 42m). I haven’t actually found any just-B-keyed on the market, so you’ll probably end up getting B+M keyed (like the stock drive).
Another guide which goes further into recovering the OS to the new drive is here: https://www.androidcentral.com/how-upgra...
Matt Beary - Antwoord
Mi duda es como instalo Chrome os a la ssd nueva
José De Jesús Lopez Guillen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 90
Altijd: 5,745
