Ga door naar hoofdinhoud
Acer Chromebook C720 Heat Sink and Cooling Fan Replacement
Wat je nodig hebt
  1. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: stap 1, afbeelding 1 van 3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: stap 1, afbeelding 2 van 3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: stap 1, afbeelding 3 van 3
    • Operating on your device while it is on, or plugged in may result in electrical shock. Make sure the device is not powered before continuing.
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Gently pry the back plate off using the plastic opening tool, leveraging the groove along the device's hinge.
  2. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 3mm screws securing the heat sink using the Phillips #0 screwdriver.
    • Remove the two 3mm screws securing the fan using the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: stap 3, afbeelding 2 van 2
    • Gently pry the fan module away from the motherboard. After a bit of force, it should pop out of its slot.
    • Carefully unwrap the wires from around the fan.
  4. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: stap 4, afbeelding 1 van 3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: stap 4, afbeelding 2 van 3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: stap 4, afbeelding 3 van 3
    • Gently disconnect the fan module from the motherboard.
Conclusie
Benjamin Rahman
517 Reputatie
3 handleidingen geschreven
IUPUI, Team S2-G5, Harley Spring 2019 Lid van IUPUI, Team S2-G5, Harley Spring 2019
IUPUI-HARLEY-S19S2G5
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 536
