Inleiding
Once your hard drive fails, it's pretty simple to replace! Just follow this guide to replace the hard drive in your device.
Wat je nodig hebt
Remove the one 4.3mm Phillips #1 screw holding the back cover on.
Remove the four 2.8mm Phillips #000 screws holding the drive onto the case.
Gently pull the drive up and away to disconnect the hard drive from its seat
Bijna klaar!
Conclusie
