Inleiding
The battery wears out over time, causing the device to not hold a charge. By replacing the battery, it will increase the length of use between charges.
Wat je nodig hebt
On the underside of the laptop towards the back, locate the battery lock slider. Push the slider, and remove the battery.
Bijna klaar!
Conclusie
You listed “spudger” under Tools, but you show a Prying Tool in the images.
Patty Remmell - Antwoord
