Inleiding
As a computer is used, it generates heat. The cooling fan pulls air through the device to cool it down. If it becomes clogged with dust or breaks, the computer will overheat.
Wat je nodig hebt
Place the laptop on a flat surface with the bottom side facing up.
Place the tip of a spudger or finger into the hole on the battery release slider.
Use the screwdriver to pierce the warranty sticker.
Unscrew and remove the #0 6mm Phillips screw and set it aside.
Use one finger to lift up the hard drive assembly from the bottom left corner.
Use a spudger or your fingernails to lift up and unclip the two gold connectors on the top of the wireless card.
Remove the SD card or placeholder by pressing the card in until it clicks and pops out.
Pull the card out.
Remove the screws.
Sixteen #0 6mm Phillips screws
One #0 3mm screw
6 andere personen hebben deze handleiding voltooid.
