Ga door naar hoofdinhoud
Acer Chromebook C710-2847 Back Cover Replacement
Wat je nodig hebt
  1. Acer Chromebook C710-2847 Back Cover Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Chromebook C710-2847 Back Cover Replacement, Battery: stap 1, afbeelding 2 van 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Back Cover Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook C710-2847 Back Cover Replacement: stap 2, afbeelding 2 van 2
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Back Cover Replacement, Acer Chromebook C710-2847 Back Cover Replacement: stap 3, afbeelding 1 van 1
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710-2847 Back Cover Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook C710-2847 Back Cover Replacement: stap 4, afbeelding 2 van 2
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Bradley Pavy
1.257 Reputatie
6 handleidingen geschreven
Cal Poly, Team 13-3, Forte Fall 2013 Lid van Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 Leden
14 handleidingen geschreven
Één opmerking
Once you have the back cover off, you can insert aluminum foil into a tiny connector, which will allow you to flash the BIOS and boot any operating system, not just ChromeOS. Using this method, I completely wiped ChromeOS from my C710 and installed Ubuntu 16.04 LTS. Definitely worth it, because now I have a sub-$300 Linux netbook with a removable battery, standard keyboard with CAPS lock (most Chromebooks don't), and no ugly Windows key.
Uncle Happy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 20
Altijd: 6,306
