Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip your Chromebook over so the bottom is facing up.
Remove the 6 mm Phillips #00 screw that holds the back cover on.
Carefully lift the cover off.
Place the cover and screw safely to the side for now.
Using the spudger or your finger, slide the battery release slider and hold in place as shown.
While holding the slider, pull out the old battery.
Remove the two 3 mm Phillips #00 screws located on the WiFi card.
Pop the wires off the WiFi card.
Tilt the WiFi card up and remove it by pulling.
Remove the fifteen 6 mm Phillips #00 screws holding on the plastic backing panel.
Remove the five 3 mm Phillips #00 screws holding on the plastic backing panel.
Use the opening tool to pull the tabs back for the ribbon cable of the Solid State Drive.
Gently pull the ribbon cable out.
Remove the Solid State Drive.
Gereedschap gebruikt in deze stap:Tweezers$3.99-
Use the opening tool to pull the tabs back for the ribbon cable located under the RAM board.
Gently pull the ribbon cable out from under the RAM board using the angled tweezers.
Use the opening tool to pry apart the seam around the outer perimeter of the back casing.
Pry apart the back casing from the keyboard housing.
Use the opening tool to pull back the tabs on the ribbon cable still connecting the keyboard and the back panel.
Use the angled tweezers to gently remove the ribbon cable.
Use a soldering iron to de-solder the nodes shown on the SD Card Reader. There will be 11 nodes above (see the wide red rectangle), and one node on each side (see two red squares).
Remove and replace the SD Card Reader.
