Ga door naar hoofdinhoud
Acer Chromebook C710-2833 SD Card Reader Replacement
Wat je nodig hebt
  1. Acer Chromebook C710-2833 SD Card Reader Replacement, SD Card Reader: stap 1, afbeelding 1 van 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 SD Card Reader Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook C710-2833 SD Card Reader Replacement: stap 2, afbeelding 2 van 2
    • Remove the 6 mm Phillips #00 screw that holds the back cover on.
    • Carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 SD Card Reader Replacement: stap 3, afbeelding 1 van 1
    • Using the spudger or your finger, slide the battery release slider and hold in place as shown.
    • When reassembling, holding of the slider is not needed.
  4. Acer Chromebook C710-2833 SD Card Reader Replacement: stap 4, afbeelding 1 van 1
    • While holding the slider, pull out the old battery.
  5. Acer Chromebook C710-2833 SD Card Reader Replacement: stap 5, afbeelding 1 van 3 Acer Chromebook C710-2833 SD Card Reader Replacement: stap 5, afbeelding 2 van 3 Acer Chromebook C710-2833 SD Card Reader Replacement: stap 5, afbeelding 3 van 3
    • Remove the two 3 mm Phillips #00 screws located on the WiFi card.
    • Pop the wires off the WiFi card.
    • Tilt the WiFi card up and remove it by pulling.
  6. Acer Chromebook C710-2833 SD Card Reader Replacement: stap 6, afbeelding 1 van 1
    • Remove the fifteen 6 mm Phillips #00 screws holding on the plastic backing panel.
    • Remove the five 3 mm Phillips #00 screws holding on the plastic backing panel.
  7. Acer Chromebook C710-2833 SD Card Reader Replacement: stap 7, afbeelding 1 van 3 Acer Chromebook C710-2833 SD Card Reader Replacement: stap 7, afbeelding 2 van 3 Acer Chromebook C710-2833 SD Card Reader Replacement: stap 7, afbeelding 3 van 3
    • Use the opening tool to pull the tabs back for the ribbon cable of the Solid State Drive.
    • Gently pull the ribbon cable out.
    • Remove the Solid State Drive.
  8. Acer Chromebook C710-2833 SD Card Reader Replacement: stap 8, afbeelding 1 van 2 Acer Chromebook C710-2833 SD Card Reader Replacement: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    $3.99
    • Use the opening tool to pull the tabs back for the ribbon cable located under the RAM board.
    • Gently pull the ribbon cable out from under the RAM board using the angled tweezers.
  9. Acer Chromebook C710-2833 SD Card Reader Replacement: stap 9, afbeelding 1 van 2 Acer Chromebook C710-2833 SD Card Reader Replacement: stap 9, afbeelding 2 van 2
    • Use the opening tool to pry apart the seam around the outer perimeter of the back casing.
    • Pry apart the back casing from the keyboard housing.
  10. Acer Chromebook C710-2833 SD Card Reader Replacement: stap 10, afbeelding 1 van 2 Acer Chromebook C710-2833 SD Card Reader Replacement: stap 10, afbeelding 2 van 2
    • Use the opening tool to pull back the tabs on the ribbon cable still connecting the keyboard and the back panel.
    • Use the angled tweezers to gently remove the ribbon cable.
  11. Acer Chromebook C710-2833 SD Card Reader Replacement: stap 11, afbeelding 1 van 1
    • Lift the keyboard off of the back casing.
  12. Acer Chromebook C710-2833 SD Card Reader Replacement: stap 12, afbeelding 1 van 1
    • Use a soldering iron to de-solder the nodes shown on the SD Card Reader. There will be 11 nodes above (see the wide red rectangle), and one node on each side (see two red squares).
    • Remove and replace the SD Card Reader.
Conclusie
Chase Wilderman
205 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G6, Harley Fall 2018 Lid van IUPUI, Team S1-G6, Harley Fall 2018
IUPUI-HARLEY-F18S1G6
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 1,047
