Ga door naar hoofdinhoud
Acer Chromebook C710-2833 Hard Drive Replacement
Wat je nodig hebt
  1. Acer Chromebook C710-2833 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Hard Drive Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook C710-2833 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the screw and cover safely to the side for now.
  3. Acer Chromebook C710-2833 Hard Drive Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook C710-2833 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Locate the hard drive.
    • Locate the four 3 mm Phillips #00 screws on each corner of the hard drive.
    • Take your driver with the PH00 bit attached and unscrew all four screws.
    • Place the screws off to the side for now.
  5. Acer Chromebook C710-2833 Hard Drive Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook C710-2833 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Once all the screws are out, gently pull the hard drive out as pictured.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nicholas Latorre
558 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G6, Nance Fall 2017 Lid van USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 36
Altijd: 1,493
