Ga door naar hoofdinhoud
Acer Chromebook C710-2833 Fan Replacement
Wat je nodig hebt
  1. Acer Chromebook C710-2833 Fan Replacement, Fan: stap 1, afbeelding 1 van 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Fan Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook C710-2833 Fan Replacement: stap 2, afbeelding 2 van 2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 Fan Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook C710-2833 Fan Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 Fan Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook C710-2833 Fan Replacement: stap 4, afbeelding 2 van 2
    • Locate the two 6 mm Phillips #00 screws on the fan port.
    • Unscrew the two screws and place them aside for now.
  5. Acer Chromebook C710-2833 Fan Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook C710-2833 Fan Replacement: stap 5, afbeelding 2 van 2
    • Carefully remove the fan from its port. You may need to use a little force as there will be an adhesive on the right side of the fan keeping it in place.
    • Locate the Molex cable connecting the fan to its port in the top left corner.
    • Disconnect the cable.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nicholas Latorre
558 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G6, Nance Fall 2017 Lid van USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 936
