Ga door naar hoofdinhoud
Acer Chromebook 15 CB5-571-C09S Track Pad Replacement
Wat je nodig hebt
  1. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 3, afbeelding 2 van 2
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 4, afbeelding 2 van 2
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement, Battery: stap 5, afbeelding 1 van 3 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement, Battery: stap 5, afbeelding 2 van 3 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement, Battery: stap 5, afbeelding 3 van 3
    • The battery is the large black rectangle located in the bottom center of the device.
    • Unscrew the single black 5 mm PH00 Phillips head screw holding the battery in place located at the top right corner of the battery.
  6. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 6, afbeelding 1 van 3 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 6, afbeelding 2 van 3 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the battery connector from the motherboard using two plastic opening tools.
    • The battery connector is the white "plug" that connects the battery to the motherboard with rainbow colored wires attached to it.
    • Use two of the plastic opening tools on either edge of the battery connector and carefully pull out the battery connector out from the motherboard.
  7. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 7, afbeelding 1 van 2 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 7, afbeelding 2 van 2
    • Once the battery has been disconnected from the motherboard it can easily be removed from the device.
    • Grab the top edge of the battery and carefully pull it up and out of the device towards you.
  8. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement, Track Pad: stap 8, afbeelding 1 van 2 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement, Track Pad: stap 8, afbeelding 2 van 2
    • The track pad is located in the bottom center of the device where the battery used to be.
    • Unscrew the seven 2 mm PH00 Phillips head screws.
  9. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 9, afbeelding 1 van 3 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 9, afbeelding 2 van 3 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 9, afbeelding 3 van 3
    • Remove the track pad connector from the motherboard.
    • The track pad connector is the white "plug" located at the bottom right corner of the motherboard with a blue and silver ribbon attached to it.
    • Use two of the plastic opening tools to grab either side of the track pad connector and carefully pull it out from the motherboard.
  10. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 10, afbeelding 1 van 3 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 10, afbeelding 2 van 3 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: stap 10, afbeelding 3 van 3
    • Grab the track pad from its corners and carefully pull it up and out of the device.
Conclusie
Sakiynah Howard
1.000 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 Lid van UMass Dartmouth, Team S1-G3, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 367
