Ga door naar hoofdinhoud
Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement
Wat je nodig hebt
  1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: stap 3, afbeelding 2 van 2
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: stap 4, afbeelding 2 van 2
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: stap 5, afbeelding 1 van 3 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: stap 5, afbeelding 2 van 3 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: stap 5, afbeelding 3 van 3
    • The Solid State Drive is the blue chip locate right beneath the fan.
    • Unscrew the 3 mm PH00 Phillips head screw located on the left side of the SSD.
  6. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: stap 6, afbeelding 1 van 2 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: stap 6, afbeelding 2 van 2
    • Grab the top and bottom edges of the SSD and carefully pull it out from the motherboard.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Sakiynah Howard
1.000 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 Lid van UMass Dartmouth, Team S1-G3, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G3
3 Leden
12 handleidingen geschreven
Één opmerking
Mine has a positive and neutral wire moving away from the SSD, and removing the chip entirely hasn't impeded operation whatsoever despite me doing it to force developer mode.
Helios Bajammin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 34
Altijd: 3,253
