Ga door naar hoofdinhoud
Acer Chromebook 15 CB5-571-C09S Screen Replacement
Wat je nodig hebt
  1. Acer Chromebook 15 CB5-571-C09S Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Acer Chromebook 15 CB5-571-C09S Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • Wedge one of the plastic opening tool in the inside of the screen cover and run it along the inside perimeter of the screen.
  2. Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 2, afbeelding 2 van 2
    • Wedge the plastic opening tool inside the back of the screen cover and run along the perimeter of the screen.
  3. Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 3, afbeelding 2 van 2
    • Remove the screen cover from the screen.
    • Pry off a pair of small covers at the back of the hinges first.
    • Carefully grab the edges of the screen cover from opposite ends and pull off the screen towards you.
  4. Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 4, afbeelding 1 van 3 Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 4, afbeelding 2 van 3 Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 4, afbeelding 3 van 3
    • Unscrew the four 3 mm PH00 Phillips head screws located on the inside corners of the screen.
    • Be sure to unscrew the inner screws attached to the screen and not the outer screws.
  5. Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 5, afbeelding 1 van 1
    • Grab the edges of the screen and pull it out towards you.
    • Do not try to remove the screen from the device at this point. There are still connections in the back that need to be disconnected before the screen can be removed.
  6. Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 6, afbeelding 1 van 1
    • Take out screen from top part of the device and lay it down flat on the key board.
  7. Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 7, afbeelding 1 van 3 Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 7, afbeelding 2 van 3 Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 7, afbeelding 3 van 3
    • Remove the screen connector from the back of the screen.
    • The screen connector is a "plug" that is connected to the back of the screen with a grey wire.
    • The screen connector is attached to the back of the screen with a sticker.
    • Peel and remove the sticker connecting the screen connector to the screen.
  8. Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 8, afbeelding 1 van 2 Acer Chromebook 15 CB5-571-C09S Screen Replacement: stap 8, afbeelding 2 van 2
    • Lift the screen back up from the keyboard and remove from the device.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Sakiynah Howard
1.000 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 Lid van UMass Dartmouth, Team S1-G3, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G3
3 Leden
12 handleidingen geschreven
Één opmerking
Where can I find the replacement screen?
Riccardo Rigamondi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 2,020
