Inleiding
This guide will walk you through the process of replacing a dead or dying battery in the Acer Chromebook 15 CB5-571-C09S.
Wat je nodig hebt
Place the device on a flat surface faced down so that the fan vents are at the top of the device.
Unscrew the single black 5 mm PH00 Phillips head screw holding the battery in place located at the top right corner of the battery.
8 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Where do you get the plastic opening tools
Instructions were perfect. Used a putty knife to pry off the back
