Ga door naar hoofdinhoud
Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement, Wi-Fi Card: stap 1, afbeelding 1 van 1
    • Place the device on a flat surface with the bottom facing upwards.
  2. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the eighteen 6 mm screws from bottom of the device using a Phillips #0 screwdriver.
  3. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: stap 3, afbeelding 2 van 2
    • With the plastic opening tool, pry along the edges of the bottom slowly to separate the back cover.
    • Be careful not to damage or crack the back cover of the device.
  4. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: stap 4, afbeelding 2 van 2
    • Carefully remove the back cover.
  5. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: stap 5, afbeelding 2 van 2
    • Locate the Wi-Fi card. It will be white chip beside the motherboard.
    • Remove the 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
  6. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: stap 6, afbeelding 1 van 3 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: stap 6, afbeelding 2 van 3 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: stap 6, afbeelding 3 van 3
    • Gently grab the edges of the Wi-Fi card and pull it out from the motherboard.
    • Carefully remove the two coaxial antenna cables that attach the Wi-Fi card to the motherboard. One is black and the other is white.
    • Have your new replacement Wi-Fi card ready to place back in the slot.
Conclusie
Avinesh Mohanaranjan
183 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 33
Altijd: 755
