Ga door naar hoofdinhoud
Acer Chromebook 15 C910-C453 Speakers Replacement
Wat je nodig hebt
  1. Acer Chromebook 15 C910-C453 Speakers Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Chromebook 15 C910-C453 Speakers Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Speakers Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Speakers Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook 15 C910-C453 Speakers Replacement: stap 3, afbeelding 2 van 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Speakers Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook 15 C910-C453 Speakers Replacement: stap 4, afbeelding 2 van 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Speakers Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: stap 6, afbeelding 1 van 3 Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: stap 6, afbeelding 2 van 3 Acer Chromebook 15 C910-C453 Speakers Replacement, Speakers: stap 6, afbeelding 3 van 3
    • Before beginning hard drive replacement, the back cover should be taken off and the battery removed to ensure no power is connected.
    • Carefully eject the black ribbon from the white base by squeezing inward at the base and gently pulling backwards.
    • Gently pull black ribbon out.
  7. Acer Chromebook 15 C910-C453 Speakers Replacement: stap 7, afbeelding 1 van 3 Acer Chromebook 15 C910-C453 Speakers Replacement: stap 7, afbeelding 2 van 3 Acer Chromebook 15 C910-C453 Speakers Replacement: stap 7, afbeelding 3 van 3
    • Disconnect the black wires where the speakers are connected to the motherboard by pulling down on both sides with two iFixit Opening Tools.
  8. Acer Chromebook 15 C910-C453 Speakers Replacement: stap 8, afbeelding 1 van 2 Acer Chromebook 15 C910-C453 Speakers Replacement: stap 8, afbeelding 2 van 2
    • Gently pull the right speaker, FYHZRF-R, upward, unlatching it from its 2 rubber joints.
    • Repeat with left speaker, FYHZRF-L.
  9. Acer Chromebook 15 C910-C453 Speakers Replacement: stap 9, afbeelding 1 van 2 Acer Chromebook 15 C910-C453 Speakers Replacement: stap 9, afbeelding 2 van 2
    • Lift left and right speakers up and untangle the connecting wire from the metal notches.
    • Remove the speakers.
Conclusie
Jacob Rakestraw
419 Reputatie
4 handleidingen geschreven
Cal Poly, Team S15-G1, Banghart Spring 2017 Lid van Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 619
