Ga door naar hoofdinhoud
Acer Chromebook 15 C910-C453 Solid-State Drive Replacement
Wat je nodig hebt
  1. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: stap 3, afbeelding 2 van 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: stap 4, afbeelding 2 van 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Solid-State Drive: stap 6, afbeelding 1 van 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Solid-State Drive: stap 6, afbeelding 2 van 2
    • Remove the screw at the left of the drive.
  7. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: stap 7, afbeelding 1 van 1
    • Remove the drive by pulling it gently to the left.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jacob Rakestraw
419 Reputatie
4 handleidingen geschreven
Cal Poly, Team S15-G1, Banghart Spring 2017 Lid van Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 40
Altijd: 5,752
