Ga door naar hoofdinhoud
Acer Chromebook 13 CB5-311-T7NN Battery Replacement
Wat je nodig hebt
  1. Acer Chromebook 13 CB5-311-T7NN Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the computer over and use a Phillips #0 screwdriver head to remove the 13 2.5 mm bottom cover screws.
  2. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: stap 2, afbeelding 1 van 1
    • Use your spudger to carefully pry the bottom cover away from the palm rest assembly.
    • Don't pull the cover away too hard once it's apart from the assembly because the headphone jack cable is still attached to the bottom cover.
  3. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: stap 3, afbeelding 1 van 1
    • Use the pointed side of the spudger to disconnect the headphone jack cable from the motherboard and completely remove the bottom cover.
  4. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: stap 4, afbeelding 1 van 1
    • Use the pointed side of the spudger to disconnect the battery cable from the motherboard.
  5. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook 13 CB5-311-T7NN Battery Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver head to remove the two 2.5 mm #1 battery screws.
    • Use your hands to remove the battery by gently picking it up.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Arin Forstadt
407 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 38
Altijd: 1,397
